Thread: AutoCad 2007
26-07-2012 #6
I think it is because you have used polylines and splines to create the parts of the drawing. I havent met a conversion program yet thet will handle them correctly for profiling. If you draw all of your parts as lines, arcs, and circles you cant go wrong.
Try this test program to see if it works for you.
The drawing is made using my layer template which I use for all of my cad drawings. It consists of all the seperate layers I need to make a valid drawing for my post processor. If you want to keep this layer template simply erase the drawing and then save the empty drawing as a layer template. Then when you want to make another drawing simply start from loading the layer template and draw everything using it, then simply rename the file when you are saving it so that you dont overwrite the template file.
Measuring stand clamp test v1.dxf
3d AutoCad CNC machine parts.
By jcb121 in forum Open Source Designs & PlansReplies: 1Last Post: 09-10-2014, 10:18 PM -
Major issue with snapping to circles -Autocad 2013
By craigrobbo in forum AutoCADReplies: 8Last Post: 01-02-2014, 09:33 AM -
FOR SALE: Xyz 560 cnc mini milling machine high spec 2007 - only used occassionally excellent
By WolfPrincess in forum Items For SaleReplies: 0Last Post: 12-11-2013, 11:36 AM -
Concentric reducer in autocad
By Web Goblin in forum Computer SoftwareReplies: 1Last Post: 24-09-2012, 03:58 PM
