Thread: Torch Height control
From the looks of it you just take a wire from the UP/ARC/DWN connections on the THC device to a spare inputs on the TB board.
The COM will go to the com or GND pin on the TB.
Then in the control software setup the THC inputs for UP/ON/DOWN to the same pins from the TB.
The + & - are power the THC device needs so come from a separate supply which by the looks of it can be anything between 5 & 35V I'd use 24V has it will better handle any noise issue's and quite cheap to find.
That link to the TB doesn't show pin outs so can't help with telling you pin numbers unless you can find a link to the manual.?
28-07-2012 #2
As usual you have it Jazz, here is an add from fleebay with some pics of the configuration at the bottom.
http://www.ebay.co.uk/itm/Proffessio...item27c96d9824Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
28-07-2012 #3
Z axis height setter
By phill05 in forum General DiscussionReplies: 7Last Post: 29-11-2016, 01:14 PM -
FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
By nobby in forum Items For SaleReplies: 0Last Post: 20-05-2014, 07:33 PM -
Plasma, Mach3, Sheetcam and a Proma Torch height controller..
By Davek0974 in forum Plasma Table MachinesReplies: 2Last Post: 14-04-2014, 03:49 PM -
Height Mapping?
By Tenson in forum General DiscussionReplies: 3Last Post: 26-10-2012, 11:40 PM -
Setting Z height with an ER32 collet
By Robin Hewitt in forum Machine DiscussionReplies: 0Last Post: 27-03-2010, 09:16 PM
