Thread: Early enquiry
30-07-2012 #1
Pending completion of my own CNC router project (and then learning how to use it effectively) I'm likely to have some 2D routing work needing to be completed PDQ from confirmed order. The items each consist of an ornate design approximately 400mm sq that needs to be engraved/routed approx. 2mm deep through wax a little thicker (approx 2.5mm). The design will be provided as a dxf.
Ideally I would like to partner with someone within easy traveling distance of Shropshire. Please pm if this is of any interest.
Doris CNC - early feedback appreciated
By woodspiral in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 08-06-2014, 10:57 AM -
Heiz T-1000, early impressions.
By pcstru in forum Heiz CNC RoutersReplies: 27Last Post: 10-09-2012, 11:06 AM -
NEW MEMBER: early stages
By dopamine in forum New Member IntroductionsReplies: 1Last Post: 04-12-2010, 01:33 PM -
Small Mill very early design stage
By leadinglights in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 15-06-2010, 01:05 AM
