Thread: Imported L298 Arduino Modules
Depending on the required micro-stepping resolution and step frequency you may be able to use the microcontroller's own analogue outputs. Alternatively something like TLC7528CN is fine. I used an 8-bit one connected to a port since that gives enough resolution for microstepping or more fancy stuff later on
. You can make the voltage reference to the DAC variable to enable different motors to be used, but make sure you use a stable reference - not just a simple voltage divider as the output of that will fluctuate too much.
Help Make 1st Step - Wiring Up Drivers to Motor and Arduino
By Treemonkey in forum General ElectronicsReplies: 10Last Post: 25-04-2013, 05:47 PM -
Any arduino coders here?
By Mad Professor in forum General ElectronicsReplies: 48Last Post: 25-03-2013, 06:07 PM -
CNC Controller with Arduino and Gamepad
By Christian Knuell in forum Electronic Project BuildingReplies: 2Last Post: 20-10-2012, 10:25 PM -
DIY arduino CNC 2 axis table
By ruthharm84 in forum Electronic Project BuildingReplies: 5Last Post: 06-05-2012, 01:54 AM
