04-08-2012 #9
Yes you can recover to a point by using belts but something has to be lost in the process.? IE: (These examples assume motors run at correct voltage)
Too small motor regards torque will need to be geared say 2:1 but the screw speed is half'd so machine speeds are lower. Plus the motors are working harder and therefore the drives to achieve the same speed has correct motors would be, this shortens life expectancy.
Supplying Higher voltage to motors will increase rpm's slightly but also create excessive heat and eventually damage the motors.
It's possible to have too large motor.? Large motors like Nema34's run quite bit slower than smaller nema23's and RPM's can be too low for the ideal required machine speeds. Gearing say 1:2 will increase screw speed but torque and resolution is lost. Same applies regards voltage.
The way gearing can work is if you match the screw to the motor.? In this case a lower or to high spec'd motor can be made to work in a way you'd like and still have the speed and resolution you want or happy with. This is done by choosing either a higher or lower pitch screw than other wise would be chosen if the ideal motor/screw combo was available. . . BUT. . Still the same torque/resolution loses/gains applies just now your using them to your advantage.!!
Just know that selecting the right motor/drive/voltage/screw in the first place can't be beaten and gearing to make some short fall up always comes at a price.!!
Nitrile O-ring belt drive - suggested stretch percentage..?
By Wal in forum Linear & Rotary MotionReplies: 23Last Post: 13-05-2014, 11:49 PM -
Commercial Machine choices...
By jashington in forum Marketplace DiscussionReplies: 4Last Post: 10-10-2013, 10:38 AM -
Drowning in choices for my plasma table project
By SemiSkilled in forum Plasma Table MachinesReplies: 4Last Post: 22-09-2013, 07:10 PM -
Which spindle with a £200 budget?
By fasteddy in forum Marketplace DiscussionReplies: 11Last Post: 29-06-2010, 11:51 AM -
Choices ...
By Wobblybootie in forum Computer SoftwareReplies: 0Last Post: 13-01-2010, 03:22 PM
