Thanks Jonathan for the 8mm dimension, maybe I'm being thick, but is that the inside diameter of the Hose? Also is this a standard size to fit directly onto the pump outlets?
John mentioned, the system will be under pressure, so will I need jubilee clips on the hose at the pump side, or is the hose a very tight push fit?
From a lot CNC builds I've seen, people have a blue liquid in the coolant system. What is this, standard automotive anti freeze?
Adil
05-08-2012 #2
It will be ID but That depends on the spindle to some degree.? I've had spindles with 6mm & 8mm barbs so check your spindle.
The pump depends.? Most I've had needed step down adaptors from 1/2" to 6 or 8mm. Any decent tropical fish place will stock these.
Again depends how you do it.? If you just choose the simple method of dropping submersible pump in tank of water then the pressure is virtually nothing.
If on the other hand it's a sealed system then the pressure will be what the pumps rated at.?
I use the simple method the water is Distilled water with Decent anti freeze 60/40% mix.
Spindle water hose connector
By cncJim in forum Marketplace DiscussionReplies: 6Last Post: 20-02-2014, 11:22 AM -
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Spindle Water Pump
By Tomnewry in forum Spindles & Drive MotorsReplies: 0Last Post: 11-08-2013, 01:05 PM -
By alex wight in forum Generic Chinese SpindlesReplies: 1Last Post: 21-09-2012, 09:57 PM
