  1. #9
    Quote Originally Posted by WandrinAndy View Post
    For instance if Jonathan were to build a new machine and dosh wasn't a limitation, I wonder if he would still use box section, what size it would be, and why?
    If NO DOSH limit then I'm 99.9% confident he wouldn't and it would be a hefty lump of ground cast Iron or some fancy composite affair.!!
    Can't hide from the fact box section sings like a canary and resonance and vibration are to be avoided so density wins every time, that's why cast iron's used so much.
    This is the kind of thing you'd buy(New) if Dosh no limit.!!! . . . .
    Here's the Y Axis carriage(pic1) which carries the Z axis(pic2) of my future 5 axis toy(Doubt I'll touch it this year thou.!).!! . . . It's one big cast iron lump with a counter balanced Z axis which is very long lump of cast and ground aluminium that runs along the roof of the main machine frame which is one big structure of steel and ground cast Iron.. . . Very very very strong and heavy 3.8ton the frame weighs.!!
ID:	6537Click image for larger version.
ID:	6538Click image for larger version.
ID:	6539Click image for larger version.
  1. Cutting forces at the the tool.
    By Spedley in forum Tool & Tooling Technology
    Last Post: 14-07-2013, 12:04 PM
  2. Cross sectional dimensions for CAD drawings
    By Husky in forum Gantry/Router Machines & Building
    Last Post: 24-02-2013, 06:19 PM
  3. stone effect plastic sheet.
    By don_jarr in forum Marketplace Discussion
    Last Post: 20-03-2012, 11:43 PM
  4. Straight sections of box steel
    By gavztheouch in forum Metalwork Discussion
    Last Post: 03-01-2012, 02:37 PM
  5. Calculating forces on linear bearings ...
    By Jonathan in forum Rails, Guideways & Bearings
    Last Post: 24-11-2010, 02:26 AM
