07-08-2012 #12
I will have a go at the analysis tomorrow evening and report back...approximately what distance do you expect between the tool tip and the bottom of the gantry?
Yes, mounting on opposite sides of steel box section is a no-no since the distance between those sides when the steel is manufactured has a much greater tolerance than for aluminium. This means that there is a high probability of the dimension being sufficiently even for the bearings to run smoothly upon the rails. Profile rails especially tolerate very little misalignment, so it is important to ensure they are mounted accurately to avoid premature failure due high stress.
Cutting forces at the the tool.
By Spedley in forum Tool & Tooling TechnologyReplies: 2Last Post: 14-07-2013, 12:04 PM -
Cross sectional dimensions for CAD drawings
By Husky in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 24-02-2013, 06:19 PM -
stone effect plastic sheet.
By don_jarr in forum Marketplace DiscussionReplies: 2Last Post: 20-03-2012, 11:43 PM -
Straight sections of box steel
By gavztheouch in forum Metalwork DiscussionReplies: 2Last Post: 03-01-2012, 02:37 PM -
Calculating forces on linear bearings ...
By Jonathan in forum Rails, Guideways & BearingsReplies: 7Last Post: 24-11-2010, 02:26 AM
