    Have you got them yet ?
    Description is vague, you could be getting just 50 plugs
    John S -
    Only ordered on the 15th, despatched on 17th so not yet.
    Just used the online chat thing to check for you:
    So it's fine - I'll let you know when they arrive if you want...
    Good discount if you buy 100, I should have done that.
    They will also give you the discount if you buy 50 of one type and 50 of another. Just asked them and ordered 50 4 pin and 50 6 pin.
    John S -
    Yea, I'll get some of the 20mm 4-pin version for steppers and maybe some more.
  5. #15
    Whats the type number for the 20mm ones ?
    John S -
  6. #16
    SH-20
    Discount if you buy 50 of those, so might just do that - group buy?
  7. #17
    Let me see if i can hold the order i have just placed and re-order.
    PM you tonight.
    John S -
  8. #18
    Thanks.. just noticed there doesn't appear to be anywhere to connect the shielding, so I reckon get 5-pin instead.
  9. Shielding in line-socket is clamped under the cord grip
    Shielding in chassis plug uses tag under mounting nut.
    I have the eBay versions of these...
    Unless you want shielding independent of chassis ground then you need the extra pin
  10. #20
    Yes managed to cancel the order but spotted another problem.
    The multi pins I already have [ forget the high speed motor ] are opposite, the chassis sockets are female. If you use these GX16-4 or the 19-4' [ or 5's ] for stepper drives the pins, when connected, are live.
    Can't seem to see the opposite version, must have a different designation but can't see what it is.
    John S -
  1. Replies: 17
    Last Post: 18-09-2013, 06:32 AM
  2. Chinese 2.2 water cooled spindle / Which VFD ?
    By dudz in forum Motor Drivers & Controllers
    Last Post: 16-08-2013, 02:22 PM
  3. Water cooled chinese spindle collets, Advice from owners please
    By craigrobbo in forum Generic Chinese Spindles
    Last Post: 11-05-2012, 12:08 PM
  4. FOR SALE: 2.2KW Water Cooled Spindle + Inverter (yes the Chinese one!)
    By Bokoshoko in forum Items For Sale
    Last Post: 06-02-2012, 12:43 PM
