20-08-2012 #21
Doesn't stop this lot:
CNC Controller 4 stepper motors Router Mill Plasma | eBay
You can just see in the photo that the stepper connector is female...
20-08-2012 #22
20-08-2012 #23
20-08-2012 #24
If its under 48v DC its not an issue, though it isn't best practice. Over 48v its a no-no...
EDIT: Its changed in the latest regs:
Insulation against Direct Contact of the conductive parts of a SELV system is required if the operating voltage exceeds 12 V a.c. or 30 V d.c. Insulation is not required if the operating voltage is at or below these values.Last edited by irving2008; 20-08-2012 at 08:05 PM.
20-08-2012 #25
Thanks Irving, saves me looking at the regs but as you say law or not it's not good practice.
So because I have to keep to regs, these are not for me. I have some of the 4 pin military type ones similar to these.
CONNECTOR Picture - More Detailed Picture about 4pin circular connector, diameter 1.5mm*4 ,free shipping Picture in Connectors from Shanhe Electric Co Ltd
But opposite, female in the socket so legal, Again all the ones on the aliexpress site seem to be oppositeJohn S -
20-08-2012 #26
Just been in the workshop and stripped two of the military plugs down as in the pic above, one from RS ? with correct female insulated chassis plug and one of the above from Ebay.
Idea was to see how easy if possible, they could have the guts swapped over, yes they can do but it takes 3/4 of an hour and you make a right mess getting wire circlips out that were never designed to be removed. So unless you can get these female chassis type that's a non runner on time alone. Certainly don't fancy taking a week off work to do 100
So the question is what other than XLR's are available in 4 and 6 pins Female Chassis mount and good for 8 amps ?John S -
20-08-2012 #27
Amphenol bayonet type, 7.5A: http://www.farnell.com/datasheets/58210.pdf
Conxall with #16 contacts, 13A: http://www.farnell.com/datasheets/83441.pdf
Switchcraft, 7.5A: http://www.farnell.com/datasheets/340542.pdf
and there are others... pretty much anything in a size 16 shell will do it...
20-08-2012 #28
Thanks Irving.
However means nothing to me,
read the data sheet, go to farnell and I get 567,945 pages to choose from.
Was really looking for something from China so i can bulk buy.John S -
22-08-2012 #29
I asked the supplier if they could do the 19mm the other way round and they've now listed these:
Aliexpress.com : Buy 4 pins push pull circular quick connector 16mm from Reliable connector suppliers on Shande Electric Factory
I'll ask if they can do the same but 19mm...
22-08-2012 #30
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Chinese 2.2 water cooled spindle / Which VFD ?
By dudz in forum Motor Drivers & ControllersReplies: 20Last Post: 16-08-2013, 02:22 PM -
Water cooled chinese spindle collets, Advice from owners please
By craigrobbo in forum Generic Chinese SpindlesReplies: 15Last Post: 11-05-2012, 12:08 PM -
FOR SALE: 2.2KW Water Cooled Spindle + Inverter (yes the Chinese one!)
By Bokoshoko in forum Items For SaleReplies: 3Last Post: 06-02-2012, 12:43 PM
