Thread: mig welders
Damn I should have looked in on this thread earlier. I have a Sterling Mig161, large gas bottle, wire, stainless wire, regulator and gas hose. You wouldnt have got it for that price though
Right, the one you have bought, the torches on these things are .... well crap! I have had a couple of them in at work to repair and the ones I have seen have had plastic liners in them which wear very quickly. If you can change this for a metal liner then I would do that. Inside the machine you will find a spindle that the reel of wire sits on, make sure this is not damaged or hanging off. Have a look at the drive rollers and mechanism. There shouldnt be too much play in them and shouldnt really have much wear unless it has been used a hell of a lot.
I'm not sure what the duty cycle of this machine is so dont know much you get out of it.
17-08-2012 #2
Man those must be Crap because I've got the industrial version Clark Mig and the torch on these are crap.!!
Stick welder would have been far cheaper and actually with decent quality rods far easier for welding box section.
Setting the Mig up is key and if not done before will take a bit of time.! . . When set right it will make you hungry.?? . . . . It should sound like Crackling bacon. . .Lol
If just using plain C/02 (Pub gas) then expect it to spit and fart. Gas makes big difference and if you can get Argo-shield then it makes for far better welding.
17-08-2012 #3
YEp jazz is right,, i fecking heat co2........argon shield every time,nice smooth weld and soun .i've a big bottle. and its still half full got it from work back in 2005 and i'v done /do alot of welding.. you can get an half size bottle of the bay for £115 to your door
If you can only afford one welder i'd go for stick!
17-08-2012 #4
Its the same everywhere mate. just lazy feckers, i'd do a bottle in every week no problem.. say if i had to go in machine shop to do the pins for the buzz bars. which would take any where from a day to 4 days.. and some one came to my bay would be gone within 3 days but i'd come back and the bottle would be empty, gas left open all the time and over night, and they wounder why the place closed down as it went bust.. oh and they don't no how to clean the shroud or how to clean up my bench after them.. I just got sick so went round welding on to their benches , must of left about 50 tacks on one and i mean they were over kill 10mm by 10 mm so it took him a while to grind it off..
problem wth people at home is they have the gas on over kill, you can not even hear the gas on mine, well you can here it kick in but soon as it dropped off you'd think you've no gas!
