Thread: Made a stand for my mill...
I keep getting a mad urge to drop a few chunky spiral reinforcement rods down inside the column of mine, then top it off with a rich cement mix. The rods are there ready for next time I'm doing concrete.
You have excellent access to plug the bottom of your column and do the same. Could be useful :D
02-01-2009 #2
02-01-2009 #3
02-01-2009 #4
02-01-2009 #5
Big cuts are fine so long as your screws are tight enough to prevent the dig in. You just make it oversize for the big cuts. I'm actually amazed how much metal these mills can hog out without breaking the tool, usually when it throws a wobbly and decides to plough off in some unexpected direction.
The time when you feel the flex is when you're going for that fine finish. It turns a corner, a sympathetic vibration sets in and you start to wonder if another few hundred lbs of metal might not be a really good idea.
I'd also fit backlash free splines in the column if only I could get it apart :D
Font help, adding a stand/base to letters so they stand up
By cockneyrebel in forum Computer SoftwareReplies: 16Last Post: 25-07-2014, 12:57 AM -
FOR SALE: £500 Vertical milling machine on stand, ready for steppers and control system
By petemono in forum Items For SaleReplies: 0Last Post: 06-02-2014, 09:52 PM -
How are these made...
By jashington in forum General DiscussionReplies: 7Last Post: 31-10-2013, 08:07 PM -
What does ER stand for in "ER11 collet"?
By bruin in forum Tool & Tooling TechnologyReplies: 4Last Post: 06-09-2012, 01:36 PM -
My home made CNC mill
By pjm in forum DIY Mill Build LogsReplies: 0Last Post: 07-06-2010, 12:01 AM
