Thread: Epoxy granite or mineral casting
30-09-2012 #17
I've done some composite work and make the odd flight case for people using sheets of a carbon/kevlar/glass mix - the easiest way I have found of getting a glassy smooth finish is to use vacuum infusion onto a rigid sheet of perspex "mould" on a flat surface - you get glassy smooth finish with no bubbles.
Not sure, but you might be able to pull a thin infusion type resin through large sized grains of "rock" of some kind mixed with chopped fibres (I keep all my carbon/kevlar/glass off cuts for this purpose). If you can't vacuum through the aggregate, then pouring into a box mould with a perspex bottom should achieve good results. All the bubbles and crappy surface will be on the top and the shiny flat surface on the bottom, which you can then demould and flip over.
Heat would be my only concern, as large volumes which don't have a matrix of some kind tend to go off with cracks in them, but a few sheets of glass or carbon layered in the mixture should help solve that.
(Eyes up the gallon container of resin on the other side of the cave ;-) ).
Edit - nearly forgot - this link might hel with ratios http://www.talkcomposites.com/11/Res...ge-calculation
How flat is a granite worktop?
By irving2008 in forum General DiscussionReplies: 28Last Post: 02-06-2021, 03:42 PM -
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM -
HELP! Problem drilling 2.39 dia hole in Ali casting
By woolley2002 in forum Machine DiscussionReplies: 4Last Post: 04-09-2013, 09:06 AM -
Casting foundry around the midlands!
By AdCNC in forum General DiscussionReplies: 2Last Post: 17-05-2011, 12:04 AM
