Thread: Epoxy granite or mineral casting
The resin system isn't a problem as I do composites in my day job I really cannot see a way of reading the 380 odd pages of theory on CNC zone and coming up with aggregate sizes
so was hoping someone here might have done the deed already
20-08-2012 #2
20-08-2012 #3
Yes that's the general idea - I've read the thread on CNCzone and a lot of it is discussing what threshold is too much aggregate since they want to save money on epoxy.
A lot depends on what you want to use it for. The thread on CNCzone is so long because they are trying to find a mixture capable of providing a stable accurate surface which will directly support linear guides. If you're only using it to fill gaps in a casting for damping, or if you embed pieces of metal and fasteners which can subsequently be machined then clearly the requirements aren't so strict...
20-08-2012 #4
Jonothan for me its easier to mould something that is all and its what im used to working with, i have the skills to mould things and this means i can do stuff at home very easily rather than pay for it machining or casting ,its as easy to mould and epoxy into place as it is to machine metal to thousandths, I suppose it depends on your background I know we have had cast bases supplied before and its purely position and glue that gets the tolerances
That was my worry they are being tight on the resin volume.Jonothan did you gleen anything on the start point for sizes you could quickly post up I have read that many combinations on there?
I do know the companies that pour this its done with technology (equipment) not dissimilar to laying concrete foundations I have seen it done and it is a lot wetter than anything aproaching the 10 percent figures I have seen touted towards the end of the thread, The rails (precision rails) were mounted on grout which was similar to moglice but with ceramic spheres in it and it did indeed look like grout till it glossed over,this glossing seems to indicate far more resin richness as the heavy particulates sink
Im assuming its coming down to a scaling factor some of the aggregates they put in the grinding bases of the carbon machines we design are up to 25 odd mm I'm thinking the smaller the machine base you scale accordingly with a wall shickness ratio
I might just have a go this weekendLast edited by mike mcdermid; 20-08-2012 at 08:35 PM.
How flat is a granite worktop?
By irving2008 in forum General DiscussionReplies: 28Last Post: 02-06-2021, 03:42 PM -
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM -
HELP! Problem drilling 2.39 dia hole in Ali casting
By woolley2002 in forum Machine DiscussionReplies: 4Last Post: 04-09-2013, 09:06 AM -
Casting foundry around the midlands!
By AdCNC in forum General DiscussionReplies: 2Last Post: 17-05-2011, 12:04 AM
