Thread: Epoxy granite or mineral casting
07-10-2012 #22
INterestingly I was musing on the idea of a reinforced concrete z-axis support to replace the round column on my mill... one day in the distant future
By way of experiement I did the FEA on a 100x 100mm 5mm wall steel tube and a 100mm x 100mm concrete post, both 750mm high.
Ignoring any difficulties fixing the concrete post, the torsional stiffness wasnt so different. With an applied 200Nm twisting load 500mm out from the centre of the post :
Steel 0.34mm movement. Weight of column 34kg
Concrete 0.45mm movement, Weight 19kg. (thats with no reinforcement inside)
So with some refinement it certainly looks doable...
How flat is a granite worktop?
By irving2008 in forum General DiscussionReplies: 28Last Post: 02-06-2021, 03:42 PM -
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM -
HELP! Problem drilling 2.39 dia hole in Ali casting
By woolley2002 in forum Machine DiscussionReplies: 4Last Post: 04-09-2013, 09:06 AM -
Casting foundry around the midlands!
By AdCNC in forum General DiscussionReplies: 2Last Post: 17-05-2011, 12:04 AM
