    The opto-isolators are very unlikely to be the limiting factor on a breakout-board as most parallel ports struggle stably to output more than around 35kHz.
    Actually you'd be surprised how many problems come from slow opto's and I've seen plenty of people on the Yahoo forum have all sorts of troubles with cheap Boards using slow opto's.!!
    Must admit Thou personally I've never had any problems.!
  1. Safe Z Speed
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 24-05-2014, 04:08 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  4. Adjusting speed with vfd
    By motoxy in forum Spindles & Drive Motors
    Last Post: 24-09-2012, 04:07 PM
  5. Top speed failing after a bit
    By Robin Hewitt in forum Machine Discussion
    Last Post: 12-11-2011, 12:46 PM
