    Rabs's Avatar
    Lives in Bedford, United Kingdom. Last Activity: 05-08-2016 Has been a member for 9-10 years. Has a total post count of 22.
    I'm afraid that the first thing I did with mine was chuck the old electronics and replace it with new drivers, a breakout board and Mach 3, so I'm probably not going to be able to help.
    I did manage to decipher the motor specs though (the markings had all worn off on mine). If you need them let me know and I'll dig out my notes.
    Hi Rabs,
    Thanks for the offer.
    I may have to do the same but I am trying to avoid that at present.
    I think I am making progress but its very slow.
    Kind regards,
    Keith
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Conqueror Design & Engineering who supplied many of the original control boards to Conect still exist, and do a conversion kit to run their own software, but are showing as out of stock - http://www.eaziform.co.uk/index.php?...ts,cncupconect
    Personally, I replaced everything in the control cabinet on mine. Modern stepper drivers will give far better performance, and modern software is far better.
    Hello m_c,
    Thanks for the link.
    I have looked there before in the past for another project.
    I do have a 4 axis stepper motor control board which is connected by USB which I may use although I got it for something else.
    Maybe I will have to fit that and update the machine.
    Kind regards,
    Keith
    Be aware that not all CNC controllers support lathe functions, so before you fit anything, check that it does support threading.
    Hello m_c,
    I will check that thanks, if it does not I may install it elsewhere.
    The board it was meant to replace runs Mach 3 so that should be OK.
    Kind regards,
    Keith
    Be aware that Mach 3 doesn't thread correctly on long threads with the single slot encoder.
    Mach 4 is getting there but it's been a long haul and as well as a $200 Mach 4 license you will need an external controller board as Mach 4 cannot exist on it's own like Mach 3.
    Linux CNC can thread and is free [ can't use USB breakout boards ] but unless you are conversant with Linux it's a steep learning curve.
    I had a look yesterday and found the Conect lathe software. It runs off a PC, what flavour I have no idea, probably DOS and I also found the manual for it.
    If you want to go the original route I can scan and upload these
    John S -
  1. FOR SALE: Free - Conect(Conquerer) lathe Board / Cheetah-II drive
    By m_c in forum Items For Sale
    Last Post: 12-07-2019, 09:07 AM
  2. scm tech 95l cnc machining centre User manual or parts lists
    By george uk in forum SCM Group Routers
    Last Post: 28-04-2015, 08:18 AM
  3. Conect 121 Lathe - The toy collection grows!
    By m_c in forum Conect Lathes
    Last Post: 01-04-2014, 12:44 AM
  4. FOR SALE: Conect 121 CNC Lathe
    Last Post: 27-03-2014, 10:44 PM
  5. Conect lathe stepper motor ID
    By Rabs in forum Stepper & Servo Motors
    Last Post: 26-08-2012, 12:25 AM
