    thankyou for entering in my post
    I'musing this 80mm mill on the picture below to do an unusual roughing out on an internal profile on cast iron, along Z axis, machining from the top to the bottom leaving an undulate surface.
    The reason why we are using this method is because the machine is not powerful enough and if we use a normal profile mill the machine stops
    CouldI do with this mill also a milling on a flat face?
    any suggestion according this matter will be very appreciated
    Thank you in advance for your help
Name:	80mm mill .jpg
  1. How flat is a granite worktop?
    Last Post: 02-06-2021, 03:42 PM
  2. Front face DIY decals advice ..
    By Fivetide in forum Metal Finishing Techniques
    Last Post: 13-06-2013, 11:23 AM
  3. SWAP: Old Low res flat screen monitor
    By cropwell in forum Items For Swap
    Last Post: 05-03-2013, 09:17 AM
  4. RFQ: flat work needed
    By kristof in forum Projects, Jobs & Requests
    Last Post: 24-11-2012, 12:00 PM
  5. RFQ: Flat work needed
    By Ricardoco in forum Projects, Jobs & Requests
    Last Post: 29-07-2012, 01:44 PM
