23-03-2012 #1
Hi guys,
We are trying to cut through 6.5mm and 9mm birch plywood sheets, ideally with a 5mm wide bit (so we can drill 5mm holes in the same pass).
We have purchased a number of different bits, double flute straight .. Up cut spiral etc..
What spindle speed do you think we should be running at? And feed rate also?
Cutting through the wood in 2/3 or three passes is fine!
We are using a 8x4 router, with a max spindle speed of 24'000 rpm (I believe).
Many thanks!
How-To: Feed Rate Calculation
By Lee Roberts in forum Machine DiscussionReplies: 20Last Post: 25-03-2020, 04:09 PM -
Feed and speed equation
By Bush Flyer in forum Spindles & Drive MotorsReplies: 7Last Post: 18-03-2014, 01:32 AM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Spindle Motor Recommendation.
By cambesol in forum Marketplace DiscussionReplies: 0Last Post: 21-11-2013, 12:15 PM -
Chamfer Feed & Speed - G-Wizard?
By Tenson in forum Computer SoftwareReplies: 4Last Post: 05-02-2013, 07:01 PM
