Thread: Hi, looking for a little help.
	23-08-2012 #1
Hi guys, just got a old camm2 engraver in working order, but just found a nylon gear cog is worn, iv tryied ebay and other sites unable to get a replacement, any one know where i can get one made, its a fine tooth cog, made of nylon, many thanks.
	23-08-2012 #2
Which axis? If I remember tight they have different number of teeth, at least mine does but that one has one original Nylon and one in Stainless, a replacement ?
Tell us how may teeth and the OD and i see what i can come up with.
My nylon one isn't great and I have a pair of 2mm pitch timing pulleys for the replacement but it's a rework job and not 10 minutes.
BTW mine was working fine but I gutted it and put Mach3 on it, still have all the original circuit boards etc, - just couldn't be arsed learning an obsolete controller.John S -
	23-08-2012 #3
hi john, Its hard to count its that fine,it approx 150 teeth, and about 25mm diamiter,the stepper motor drives it across, not sure if thats x. y. z. not had one before thanks.
	23-08-2012 #4
Ok that's easy to source then.
You just need one with about 150 teeth and about 25mm diameter
				John S -
	23-08-2012 #5
	23-08-2012 #6
You are either younger than me or got a better memory..............
John S -
