Thread: Y axis stalling
    Thanks for the help. How can I tell if the alignment is off to bend the leadscrew? And is that fixable?
    I do remember noticing that the leadscrew was not totally concentric when I first got it. I assumed it was just due to the leadscrew being made from really long thread which got slightly bent at some point in the Chinese factory.
    Quote Originally Posted by richie00boy View Post
    With careful measurements and visual checks.!! Aligning ballscrew and nut is tedious job but very important to both prevent bending and getting the best performance.
    If alignment is off enough to bend the screw it should easily be visible by manually running the gantry along it's length carefully watching the screw to see if it's bending. Also if you turn the screw by hand with motor disconnected and you feel it stiffen has it nears ends this is good indication some things off.!!
    Can't really comment on what would be needed to fix without seeing how ends are fixed and how much off it is.?
    If you take one of the bearings off and turn the screw by hand, as the nut approaches the other bearing it should be fairly obvious if it's misaligned, particularly if you can get the nut quite close to the bearing.
    OK, before I take things apart a bit more and get lost, here is what I have found.
    1. The motor knob becomes stiff when the leadnut under the gantry can be at almost any point along the length of the leadscrew, i.e. not just at the ends.
    2. I have unscrewed the leadnut from the gantry and can see the leadnut housing bobbing about relative to the gantry again at almost any point along the length of the leadscrew.
    I'm thinking that there could be two ways for bending the leadscrew. One if the leadnut was not mounted centrally, and the other if the chassis is out of square or the leadscrew not exactly in the middle of each end piece. How can I check for all of these? Because there is also the possibility that a bent leadscrew has been fitted at the factory - which I'm hoping is the case and my machine is fundamentally sound. Also I would not be that bothered if the leadnut was not mounted centrally because if I convert to ballscrews I would be fitting a new mount.
    Ok you can't feel for stiffening properly with the motor connected because of the Detent of the motors to do it properly you MUST remove motor.
    Without seeing the exactly how the ends are fixed and the leadnut mounts to gantry then it's hard to say. But if it's how I think then to get a rough idea you'll need to remove the bearing at one end and the run the gantry to that end with leadnut attached and see if the screw is central in the hole.? This should give you some indication if it's misaligned.
    The most common reason for bending is because the leadnut is either lower or higher than the ends in middle of it's travel where it's the most bendy it then lifts or pulls down on screw when approaching ends bending screw in process.
    To check if screw ends are equal is a simple case of measuring from one reference edge to screw centre(or edge) for both vertical and horizontal. IE: Machine side to screw for horizontal and End plate edge to screw for vertical.
    Then if ok loosen the leadnut mount from the gantry so there's no pressure on it and run the gantry to one end. Now check for any gap between Mount and gantry.? Now Run the gantry to other end and see if the gap is the same. Do the same at several points along the screw.
    If all is ok the gap should be same or very very close to none, ideally you want light interference fit.! Now it's just a case of shimming the gap so when tightened there's no pressure or pulling on the screw.
    If there's no gap and there's tight fit between leadnut mount and gantry then you'll need to remove some material from leadnut mount.
    If your leadnut mount doesn't bolt onto flat surface and instead has drop bracket that which fastens to gantry cross brace then you'll need to loosen the bracket to slip fit and put witness marks on bracket and brace. Then run gantry up and down it's length and watch if marks move.? If they do then try loosening lead nut from the bracket and find balance using both bracket and leadnut mounts, failing that you'll have adjust the end fixings.!!
    If the machine is out of square then you'll feel it going tight when pushing gantry up and down it's length with leadnut disconnected. Being honest thou with the sloppy linear bearings on these machines I doubt you'll feel it. That said for it to be bad enough to bend leadscrew you'd most certainly be able to visually see it.!!
    Obviously I'm giving adjustment suggestions blind has I can't see your machine and how things are fixed but hopefully should give you an idea of what i mean.!!! . . .. . . OR I could have just blown your mind. .
    The stiffening is a lot worse than other axis though and I can see the leadscrew is bent so I think I'm satisfied with that as the fault diagnosis. The gantry runs nice and free up and down the rails with the leadnut disconnected, so I'm happy that things are square. I can't feel any play.
    I don't think I can do these other tests being mentioned because the leadscrew is bent, therefore it's going to make the leadnut not align with the bearing hole when looking through, etc. If it was the leadnut alignment that bent it, well I'm ditching that anyhow.
    So what I need now is to spec and purchase a suitable replacement ballscrew system. Then once I have that I can do these trueness checks. I'm going to have to do them anyway to work out the mounting for the ballnut aren't I?
    I'll start a new thread for the ballscrew.
    Just as a last check, here is a video of the leadscrew showing the runout. The leadnut housing has been unbolted from the gantry to show how it rocks due to the bent leadscrew. Hopefully you will agree that this is the cause of the problem.
    http://www.readresearch.co.uk/person.../leadscrew.mp4
    Take it you have the mounting bracket loose.? . . . But No not at all I've seen worse than that an still work fine.!!. . . . . For this to cause stalling it should only possibly be at very high speeds and even then with that amount of wobble over such short distance I doubt it would.!!
    If this is causing your stalling then I think you may have the motors tuned too high.? What do you have set for Acceleration & Velocity in motor tuning for each axis.?
  1. rough traversing and stalling only in main screen
    By davethefixer in forum Machine Discussion
    Last Post: 12-05-2013, 08:34 AM
  2. DPC spikes stalling stepper motors
    By Mad Professor in forum Stepper & Servo Motors
    Last Post: 23-10-2011, 10:21 AM
  3. Clicking sound from stepper motor & stalling
    By francooz in forum Stepper & Servo Motors
    Last Post: 06-02-2011, 04:15 PM
  4. X and Y axis stalling
    By francooz in forum Machine Discussion
    Last Post: 05-01-2011, 06:27 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
