Thread: 3-Axis CNC Mill Project
17-10-2012 #28
If you use a 30T pulley on the ballscrew then you can put a 30T pulley on the motor to get 1:1, or use a 15T pulley on the motor (which is unlikely to be needed much if at all, but it's good to have the option) to get 1:2 ratio. It's best not to use smaller than a 15T pulley since the belt will wear quicker and you may not have enough teetth engaged with the pulley if it is too small.
The moment of inertia of a cylinder (which is essentially what the pulley is) is proportional to its squared, so a small increase in the pulley diameter will cause a relatively big increase of the inertia. The torque required from the motor is proportional to the inertia, so you want to minimise it if possible - hence use the smaller pulley, 30T instead of 40T.
Emco mill 50 Y axis travel?
By gavztheouch in forum Emco Milling MachinesReplies: 0Last Post: 01-03-2014, 11:10 AM -
WANTED: 3-Axis Mill recommendations
By TomB in forum Items WantedReplies: 0Last Post: 05-10-2012, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
FOR SALE: Mini Mill Z-Axis stuff
By pjm in forum Items For SaleReplies: 0Last Post: 17-06-2010, 10:00 PM
