Thread: 3-Axis CNC Mill Project
Then on to a mock assembly to make sure it looks ok:
Perfect, a solid accurate level frame with enough room underneath the table for housing the control, pc, drives, tooling etc. Finally I laid the aluminium extrusion profile I’m using for the machine table on top:
Next up is to finalise the design for the hardened linear rails, linear bearing guide blocks, ball screws and stepper motors; that said I can then cut this profile to suit, and make the carriage for the x axis as shown atop the sketch:
Sit down time with a good bottle of ale:
Hopefully when its complete I’ll be able to mill 2D images to 3D, and produce high precision parts.
Thanks.
25-08-2012 #2
Wouldn't the frame be stiffer with a few diagonal members added?
26-08-2012 #3
26-08-2012 #4
Think you'll find he's correct and Yes I am familiar with your materials.!!
What your not accounting for is the Mass of the gantry and it's inertia.?
It doesn't so much matter what your cutting the Mass of the gantry will have a big affect and actually if soft material then usually means high feed rates which affectively makes the gantry a very heavy thing indeed which will put more stress upon the frame trying to twist it and push it out of shape.!! . . . At this height and narrow width and also from the look of your doodle showing the high gantry sides I wouldn't be one bit surprised if it didn't try to tip it over when rapiding at even mild speeds.? . . . I would certainly think about bolting it down or have plenty of ballast low down.!!
For the little extra cost it would be well worth it to brace the frame now rather than find out it's twisting and moving around while cutting then have to do it later and go thru all the shimming and setting up again.!!
Emco mill 50 Y axis travel?
By gavztheouch in forum Emco Milling MachinesReplies: 0Last Post: 01-03-2014, 11:10 AM -
WANTED: 3-Axis Mill recommendations
By TomB in forum Items WantedReplies: 0Last Post: 05-10-2012, 10:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
FOR SALE: Mini Mill Z-Axis stuff
By pjm in forum Items For SaleReplies: 0Last Post: 17-06-2010, 10:00 PM
