Was that 10 a week or 100 a week?
If the letters are 6"/150mm high on 11mm MDF and you are talking abut low run rates then if you started with a small blank precut say 170mm x 170mm you'd get 98 letters out of a sheet of MDF with <5% wastage. You could get B&Q or whoever to precut these blanks for a small sum about £10. In that case you could get away with a much smaller/lighter/cheaper machine around £500 - 600 new or even less if you picked up an ebay used bargain. You could even build a suitable machine for that sort of work from MDF for £300 or so, to an existing established design, which for someone with your evident hand-working skillls should be relatively straightforward.
While obviously cutting from a full or half sheet of MDF is preferable from a speed/materials cost/job run perspective (especially if you were doing a 100 a day!) its something you could then aspire to as the business develops, by which time you'd have the knowledge/skill to make the more complex decisions about specifications and whether to buy/build.
Heres an example of what you could buy (not suggesting you get this one, before Jazz leaps in lol) http://www.ebay.co.uk/itm/Sable-2015...item3a791045f0
The Following User Says Thank You to irving2008 For This Useful Post:
Cutting metal shapes
By jmac80 in forum Metalwork DiscussionReplies: 31Last Post: 27-11-2013, 10:32 PM -
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
RFQ: Small wooden parts
By Tabclear in forum Projects, Jobs & RequestsReplies: 17Last Post: 01-03-2013, 05:46 PM -
wooden joints
By luke11cnc in forum Woodwork DiscussionReplies: 7Last Post: 18-10-2012, 11:59 PM -
newbie need advice on cnc machine to purchase? routoutcnc machines any good?
By wyndham in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 27-05-2011, 08:54 PM
