Thread: Earthing?
    Earth loops are always trying to sneak in and act like shorted out transformers. For example, an AC electric motor has an earth connection that goes to it's casing and that casing connects to the machine body which has a seperate ground connection. That is an earth loop with some major magnetic field activity in one corner and current starts to flow. Not only does the motor earth wire heat up but so do any other loops in the system, especially if they pass through the machine body. The Volts may be low but the current can be enormous.
  2. The Following User Says Thank You to Robin Hewitt For This Useful Post:
  3. #2
    Yep it's possible but lets not confuse the poor bloke any more than need be Robin.!! . . . In the main If he sticks to the star grounding then he shouldn't have any issue's.
  1. Laser Machine Grounding/Earthing
    By Want2build1 in forum Laser Machines & Building
    Last Post: 09-02-2015, 10:18 PM
