Thread: Earthing?
Why is that "properly"? I like big fat wires, as big as will fit in the screw terminals on the driver. I run my big fat wires through flexi-plastic conduit to keep it tidy.
Why would you want screened? Armoured would be more understandable.
If you are worried about interfering with your high speed computer connections, you could screen those perhaps.
15-01-2017 #2
Robin, now you are confusing me:)
As far as I understand, "armoured" hardly offers any electromagnetic containment. All signal cables will be screened. I will use flexi conduit for the motor wires too. Do you mean you run 8 separate fat wires inside the conduit?
EdwardLast edited by Edward; 15-01-2017 at 01:50 PM.
15-01-2017 #3..Clive
15-01-2017 #4
Thanks Clive.
The 3.1Nm motor would draw a maximum of 4.2A, but we all know that in reality it's probably about half of that anyway.
So a cable of 1mm2 (normally rated for at least 10A) will more than cover this. However, I wonder if there is any benefit in using a thicker cable, other than robustness...or obsession:)
I like the motor covers with the glands. Is this something you printed yourself, or are they readily available for the Nema23 frame? BTW, my Z motor is to the side of the column, just like in your picture.
Edward
15-01-2017 #5
I printed these a few years ago but since then I have milled them from various blocks of plastic including those fencing posts made from car tires. If you do a search for hem I have seen them in Europe somewhere
https://www.hardware-cnc.nl/en/winke...nema-23-detail
http://www.thingiverse.com/thing:243126..Clive
15-01-2017 #6
Now't wrong with a bit of healthy obsession
Thin cable is fine and dandy if you were lighting a bulb or charging your iPhone with a bit of AC but this cable has more to do than that.
On the other end of it is a hefty inductive load, it may have tuned itself a bit to reduce the peak but sooner or later it is going to want to reverse the current in a coil winding PDQ. It will try to control that current using a chopper circuit which depends on measuring the current flowing some way away. Did you fit the optional braking resistors?
Fat, low resistance cable takes the strain off more expensive components.
15-01-2017 #7
15-01-2017 #8
15-01-2017 #9
Hi Dean
I knew you would be along to explain why everyone seems hell bent on screening and tin boxes despite the problems they cause. This is something that has bothered me for some time, a trap I think I have fallen in to myself.
Ready when you are, I am all ears...
Robin
15-01-2017 #10Robin would you please explain how to fix a braking resistor to the motor in this caseDid you fit the optional braking resistors?
Laser Machine Grounding/Earthing
By Want2build1 in forum Laser Machines & BuildingReplies: 31Last Post: 09-02-2015, 10:18 PM
