Thread: Earthing?
    Robin, now you are confusing me:)
    As far as I understand, "armoured" hardly offers any electromagnetic containment. All signal cables will be screened. I will use flexi conduit for the motor wires too. Do you mean you run 8 separate fat wires inside the conduit?
    Edward
    Quote Originally Posted by Edward View Post
    Edward
    Edward just do as you suggested chop the wires off about 250mm from the motor and then join them to the CY cable personally for the motors you are using I would go with 1mm size. If you want to be posh you can get an end cover for the motors and take the cy cable into that.
ID:	20370Click image for larger version.
    Thanks Clive.
    The 3.1Nm motor would draw a maximum of 4.2A, but we all know that in reality it's probably about half of that anyway.
    So a cable of 1mm2 (normally rated for at least 10A) will more than cover this. However, I wonder if there is any benefit in using a thicker cable, other than robustness...or obsession:)
    I like the motor covers with the glands. Is this something you printed yourself, or are they readily available for the Nema23 frame? BTW, my Z motor is to the side of the column, just like in your picture.
    Edward
    Thanks Clive.
    Edward
    I printed these a few years ago but since then I have milled them from various blocks of plastic including those fencing posts made from car tires. If you do a search for hem I have seen them in Europe somewhere
    https://www.hardware-cnc.nl/en/winke...nema-23-detail
    http://www.thingiverse.com/thing:243126
  5. The Following User Says Thank You to Clive S For This Useful Post:
  6. #5
    Now't wrong with a bit of healthy obsession
    Thin cable is fine and dandy if you were lighting a bulb or charging your iPhone with a bit of AC but this cable has more to do than that.
    On the other end of it is a hefty inductive load, it may have tuned itself a bit to reduce the peak but sooner or later it is going to want to reverse the current in a coil winding PDQ. It will try to control that current using a chopper circuit which depends on measuring the current flowing some way away. Did you fit the optional braking resistors?
    Fat, low resistance cable takes the strain off more expensive components.
  7. #6
    I don't have braking resistors.
    Here is a pic of my conversion, the Sieg SX2.7 with the drivers, etc waiting to go in a suitable box.
    Edward
  8. #7
    Robin your talking shite again and confusing people with your ridiculous answers.!. . . If your not going to help people with relavant or helpful replys then why don't you STFU.!!
  9. #8
    Hi Dean
    I knew you would be along to explain why everyone seems hell bent on screening and tin boxes despite the problems they cause. This is something that has bothered me for some time, a trap I think I have fallen in to myself.
    Ready when you are, I am all ears...
    Robin
  10. #9
    Hi Dean
    Robin
    Not even going to get into it with you Robin because it's well documented why shielded cable is required. To say it's not needed is like saying this Gun may or may not have bullets put it to your head pull trigger to find out. .
  11. #10
    Robin would you please explain how to fix a braking resistor to the motor in this case
  1. Laser Machine Grounding/Earthing
    By Want2build1 in forum Laser Machines & Building
    Last Post: 09-02-2015, 10:18 PM
