Thread: Earthing?
  1. #29
    Edward's Avatar
    Lives in London, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 114. Received thanks 3 times, giving thanks to others 0 times.
    Robin,
    I take it these "battles" have been going on for a while:)
    I meant running a 4 core cable from motor to driver in one go, without connectors (XLR or similar) on the panel - less work soldering pins. At the motor side, just cut the 8 cables and solder/insulate accordingly to the 4 core cable.
    Not that I've ever experienced any problems with connectors, but I am just thinking that once all is in place, I won't be moving the box anywhere, so using XLR or GX16 connectors is not going to be necessary, though I suppose it looks a touch more professional, if one is bothered about that.
    If for whatever reason I need to disconnect a motor or something in the future, it's not a big deal to do it from the drive own connector.
    Edward
  1. Laser Machine Grounding/Earthing
    By Want2build1 in forum Laser Machines & Building
    Last Post: 09-02-2015, 10:18 PM
