Thread: Drag Chains
03-09-2012 #2
The chains are sized by internal width and height and then bending radius. What you could do is bundle together the cables and hoses that you need to run to the z axis. Try laying them in a 2 layer formation, ie the two coolant tubes and the air tube on the bottom then the two power cables on top then measure the width and height then add at least 50% for "design modifications". Then just pick from the Igus charts. Igus does make good chain. We use it alot at work.
Drag Knife anyone?
By JoeHarris in forum Tool & Tooling TechnologyReplies: 22Last Post: 07-11-2019, 08:32 PM -
Cable drag chain
By birchy in forum General ElectronicsReplies: 9Last Post: 04-01-2014, 12:45 AM -
Drag chains
By jcb121 in forum General DiscussionReplies: 4Last Post: 14-05-2012, 11:44 AM -
wiring for drag chains
By johngoodrich in forum General ElectronicsReplies: 10Last Post: 09-02-2012, 08:44 PM -
Spring loaded drag engraver
By Sharx in forum Tool & Tooling TechnologyReplies: 1Last Post: 16-02-2011, 11:10 PM
