    Thanks Robin,
    yes, water jet cutting has intrigued me since i first heard about it but the machines seem expensive and then you have the abrasive material usage costs.
    I did a lot of work on hydraulic production machinery at one time..injection moulding, template copying etc and the idea did pop into my head that i might be able to build one but that will have to be another project for another time i think :)
    Desktop water jet cutting...way to go...
    Can the abrasive be reused or does it just recycle until its no longer effective?
    Quote Originally Posted by camhguh View Post
    I think someone has to empty the filter tank once a year, supposed to be one pig of a job.
    I did see someone offering a gizmo that separated out the garnet from the dross but no details.
    I find milling acylic requires something to get the heat out, once it starts melting the tool bit is doomed. I usually just put the suds on. Icky.
    Wonder if you can get an Abrafile blade for a bandsaw? That'd do it.
    Lives in East Lothian, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    I've cut acrylic with the bandsaw and jigsaw, and the only way I've found to avoid clogging, is to cut as hard as you physically can. By that I mean full weight behind the jigsaw, and worry about not being on the line later!
  1. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  2. Laser cutting Machines
    By Want2build1 in forum Laser Machines & Building
    Last Post: 13-05-2014, 01:58 PM
  3. RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
    By nobby in forum Projects, Jobs & Requests
    Last Post: 29-04-2014, 12:36 PM
  4. RFQ: RFQ.. Acetal or acrylic... laser cut or routed.
    By purpose in forum Projects, Jobs & Requests
    Last Post: 12-12-2013, 12:03 PM
  5. laser cutting ally plate
    By i2i in forum Tool & Tooling Technology
    Last Post: 21-02-2013, 08:47 AM
