Thread: Hi from Cumbria..
If you are only cutting Depron you may want to look at a laser.
Advantages of a laser over a router is no fixturing problems , don't need to fasten soft stuff down to cut, speed and simplicity of use.
Disadvantages are only thru cuts are allowed, no pocketing.
Sorry to throw another choice into the mix
John S -
09-09-2012 #2
thanks for the pointer WandrinAndy, i'll have a good read through that..
blackburn mark, I can't ever seeing me wanting to cut anything other that foam, maybe some 2mm ply, was hoping that if i kept it to these materials it would keep the cost down.
John S, never thought of a laser, i'll look into that, would that involve more cost..? I haven't got a big budget..
Thanks for the replies..
09-09-2012 #3
[QUOTE=Kickstart;35335]blackburn mark, I can't ever seeing me wanting to cut anything other that foam, maybe some 2mm ply, QUOTE]
im assuming it would make sense to run your axis on toothed belts(light weight fast moving gantry) if you intend using a laser (no cutting force/resonance)
that should keep the price down on the mechanics (no ballscrews to pay for)
i know nowt about lasers, i think john s has a 40w laser, he'll be your man for that side of things :)
09-09-2012 #4
Thanks Mark.. that sounds like a plan..
NEW MEMBER: new member in west cumbria
By chris in forum New Member IntroductionsReplies: 3Last Post: 28-11-2013, 09:16 AM -
NEW MEMBER: How do from Cumbria
By EddyCurrent in forum New Member IntroductionsReplies: 0Last Post: 17-08-2013, 06:56 PM -
NEW MEMBER: Hey from Cumbria
By ed_456 in forum New Member IntroductionsReplies: 1Last Post: 15-01-2011, 04:24 PM -
NEW MEMBER: Whitehaven, Cumbria
By Keledge in forum New Member IntroductionsReplies: 1Last Post: 05-10-2010, 11:39 PM
