Ok I see where your going wrong.? Nope forget the Va rating for now the only bit your interested in is the secondary outputs.
You have 2 and you can either have them separate so effectively making 2 completely separate PSU's or wire them together to make one large supply.
If wired in series then you add the voltages for each secondary together but keep the amps the same. Wire in Parallel then you do the opposite.
IE 625Va 2 x25V Can have this combination.?
1 x 25Vac x 12A = 1 x 35Vdc @12a PSU
OR
1 x 50Vac x 12A = 70Vdc @12A Psu = Wired series
Or
1x 25Vac x 24A = 35Vdc @ 24A Psu = Wired Parallel
11-09-2012 #2
Denford Triac VMC year 2000 motors spec
By suesi34e in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 17-11-2013, 11:44 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM -
FOR SALE: Servo Spec gearbox's ---- Any offer considered
By Jimmybristol in forum Items For SaleReplies: 11Last Post: 30-05-2011, 11:04 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
