12-01-2014 #101
Following from Jonathan's post #99
Transformer Inrush - Open Electrical
The Following User Says Thank You to EddyCurrent For This Useful Post:
13-01-2014 #102
Good article, but they could have expressed the final equation more clearly to demonstrate their point. Also, it's a bit pointless to solve the differential equation using Laplace transforms when you can trivially separate the variables. This is how I did it:
From Faraday's law:
Seperate variables:
Use sin(A+B) identity to make it easy to integrate:
Integrate:
Use cos(A+B) identity to simplify:
. (1)
When the transformer is switched on, we have the initial condition relating to the residual flux:
So substitute this in to (1) to find constant, k:
So the solution is:
So now it's easier to see that the . term is a constant, which introduces a DC offset that disappears when the switching angle is . ... i.e at the peak voltage.Last edited by Jonathan; 13-01-2014 at 12:28 AM.
13-01-2014 #103
I used to like Laplace transforms but that was 40 years ago, I've never needed to use them since
13-01-2014 #104
Denford Triac VMC year 2000 motors spec
By suesi34e in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 17-11-2013, 11:44 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM -
FOR SALE: Servo Spec gearbox's ---- Any offer considered
By Jimmybristol in forum Items For SaleReplies: 11Last Post: 30-05-2011, 11:04 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
