    Yes 50v wired parallel is double the amps but they are half the rating of the 25V so workout the same.
    Could you just clarify what you mean by rating in that context? VA? I ask because the only way I understood that the 25V wired in series would equal the amps from the 50v wired in parallel would be for the 25V to start with double the VA, ie
    50V-50V 500VA parallel would be: 50*1.4 = 70V@500+500 / 70 = 14.2A
    25V-25V 500VA series would be: 25+25*1.4 = 70V@500 / 70 = 7.14A
    so you would actually need 25V-25V 1000VA to get: 25+25*1.4 = 70V@1000/70 = 14.2A
    There's clearly something fundamental I'm missing here.
    I really appreciate both of your inputs, time and patience, just in case I didn't mention it already!
    When you put the windings in series add the secondary voltages, but at the same current. In parallel you get the same voltage as for one winding but twice the current. Either way the VA rating has to remain constant for the same transformer.
    Just what Jonathan says but to make it clearer look at the transformer output current ratings for these two transformers.
    Both are 625Va but first is 2x25V second is 2x50v.
    Standard Range Toroidal Transformers: CM0625225: 625VA 230v to 2x25v
    Standard Range Toroidal Transformers: CM0625250: 625VA 230v to 2x50v
    If you wired the 2x25V in parallel not series you'd still have 25V but @ 24A So obviously 2x50V in paralle is 50V @12A (6A x 2)
    Ahh, wait a second. Is the 625VA shared between the two outputs or per output?
    Quote Originally Posted by Rogue View Post
    Ok I see where your going wrong.? Nope forget the Va rating for now the only bit your interested in is the secondary outputs.
    You have 2 and you can either have them separate so effectively making 2 completely separate PSU's or wire them together to make one large supply.
    If wired in series then you add the voltages for each secondary together but keep the amps the same. Wire in Parallel then you do the opposite.
    IE 625Va 2 x25V Can have this combination.?
    1 x 25Vac x 12A = 1 x 35Vdc @12a PSU
    OR
    1 x 50Vac x 12A = 70Vdc @12A Psu = Wired series
    Or
    1x 25Vac x 24A = 35Vdc @ 24A Psu = Wired Parallel
    OR
    Or
    I have a few more questions I shall need to read into I think. You've already been more than patient with me! Thank you both.
    Now, are you agreeing with me or correcting me? Because what you said is what I thought I said, if you follow me.
    Who you asking Jon or Me.? Either way we are both saying series you 2 x volts 1xamps or parallel 1 x volts 2 x Amps. . . BUT . . the amp output rating for 25v transformer are double the 50V.!
  1. Denford Triac VMC year 2000 motors spec
    By suesi34e in forum Milling Machines, Builds & Conversions
    Last Post: 17-11-2013, 11:44 PM
  2. Advice on spindle inverter spec
    By badgerman in forum Spindles & Drive Motors
    Last Post: 15-09-2013, 09:26 PM
  3. Hiwin linear blocks HGW 20 CC - what preload to spec?
    By range3rrr in forum Rails, Guideways & Bearings
    Last Post: 24-08-2011, 11:44 PM
  4. FOR SALE: Servo Spec gearbox's ---- Any offer considered
    Last Post: 30-05-2011, 11:04 PM
  5. System spec and Mach3
    By gorbo in forum Computer Hardware
    Last Post: 23-01-2011, 03:25 PM
