11-09-2012 #10
Just what Jonathan says but to make it clearer look at the transformer output current ratings for these two transformers.
Both are 625Va but first is 2x25V second is 2x50v.
Standard Range Toroidal Transformers: CM0625225: 625VA 230v to 2x25v
Standard Range Toroidal Transformers: CM0625250: 625VA 230v to 2x50v
If you wired the 2x25V in parallel not series you'd still have 25V but @ 24A So obviously 2x50V in paralle is 50V @12A (6A x 2)
Denford Triac VMC year 2000 motors spec
By suesi34e in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 17-11-2013, 11:44 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM -
FOR SALE: Servo Spec gearbox's ---- Any offer considered
By Jimmybristol in forum Items For SaleReplies: 11Last Post: 30-05-2011, 11:04 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
