11-09-2012 #9
So we were saying mostly the same thing. That's a good start :)
I think I've worked out where my mental block is for this element at least. I was treating parallel as increasing A rather than decreasing the division of A. In other words, I was thinking of two outputs, each with 50V 625VA. Parallel would make this one output of 50V 1250VA. Rather, I should be looking at it as two outputs of 50V sharing 625VA between them - effectively making it 100V / 625VA = 6.2A. Wiring it in parallel would then have the same VA but divided by less, which has the same end effect as doubling it: 50V / 625VA = 12.5A. When I look at it like this, your previous comments make more sense so I guess I'm on the right track.
And you wonder why I get jittery with mains power
Denford Triac VMC year 2000 motors spec
By suesi34e in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 17-11-2013, 11:44 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM -
FOR SALE: Servo Spec gearbox's ---- Any offer considered
By Jimmybristol in forum Items For SaleReplies: 11Last Post: 30-05-2011, 11:04 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
