20-09-2012 #13
Yes. The originally spec'd relays (Rapid 60-1310) were fine for both positions.. I would socket mount them.
The RS699-6869 is overkill with the inbuild LED etc.
The RS619-3013 would be fine for Relay 2, but as a PCB mounted device its hard to use.
If price is critical then consider using Rapid 60-1667 in sockets. While these are only rated at 240vAC/5A and 600VA for the switching rate you will use them for they'll be fine and if you're paranoid you could wire the contacts in pairs.
Denford Triac VMC year 2000 motors spec
By suesi34e in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 17-11-2013, 11:44 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM -
FOR SALE: Servo Spec gearbox's ---- Any offer considered
By Jimmybristol in forum Items For SaleReplies: 11Last Post: 30-05-2011, 11:04 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
