15-08-2013 #1A small problem with wiring the secondary in parallel is that if the amount of turns on them is not exactly the same the transformer is not as efficient.
Originally Posted by Rogue
I got around this by rectifying the two windings separately then combining them at the DC side.
Just a thought. ..CliveLast edited by Jonathan; 15-08-2013 at 10:25 PM. Reason: Fixed quote formatting
15-08-2013 #2
Intriguing. I've seen a bit posted about the AM882 drivers but a lot of it didn't seem positive. On some further reading, most of the issues seem to be down to user error and misconfiguration. The price difference at this stage is minimal as well.
Is it better to match up the driver output with the motor rating exactly, or leave a bit of a margin?
Also intriguing, though how would you establish that? Would it be as straightforward as checking the voltage from each output separately? I suspect I will take the easy way out and just use the one rectifier, but I'm intrigued by the idea.Last edited by Rogue; 15-08-2013 at 10:14 PM.
15-08-2013 #3I have just joined the two outputs from the caps together with no problems at all. ..Clive
15-08-2013 #4
In theory you should be safe to run any driver up to its rating, since that's the whole point of a rating, if you can trust it. In reality however it's always best to overrate the drivers if you can, since then they will run at a lower temperature which prolongs the life of the components.
Yes - the difficult bit is determining how much of a mismatch would pose a problem.Last edited by Jonathan; 15-08-2013 at 10:23 PM.
15-08-2013 #5
Hi Jonathan, thanks for chipping in again. I'm still aiming to finish this before you finish at Uni so I'll need you to work towards a PhD, should give me enough time.
I was thinking about this from the point of view of the stepper motors (4.2A) rather than the drivers. Either of the two drivers discussed are rated higher than the stepper (up to 5.2A for the DM856, up to 8.2A for the AM882) so there is plenty of margin. My question was whether it's better to run the steppers at their max or give them a bit of a margin. If your answer still applies (which logic suggests it does) then it seems reasonable to set the drivers for a little under 4.2A.
15-08-2013 #6
Agree here and I've built both ways and never seen any difference to machine which is what matters at end of day. I buy what's cheapest or available and don't care which.
Yes there have been but that's mostly been because they have little experience or never used digital drives before but trust me they are fantastic drives and give super smooth performance with great resonance handling. The Fact you can configure them thru software helps if you have problems with resonance or just want to get the best performance you can.
Yes it's always better to match current to motor ratings but not go higher. The only margin you want to leave is on the voltage but it's also always better if the drives are not max'd out on current IE max current setting = motor current so the drives not working flat out.!Last edited by JAZZCNC; 15-08-2013 at 10:32 PM.
15-08-2013 #7
15-08-2013 #8
15-08-2013 #9
That's the plan, however at work they seem to want me to do the PhD whilst working them, in which case you've only got a year left!
Yes my answer does still apply. As you increase the current in the motor windings, the copper losses increase by the square of the current, so the motor will get hotter. The degradation of the insulation on the motor windings is dependent on the temperature, as with most chemical reactions, so according to the Arrhenius equation we can say (very approximately) that if the motors run 10° hotter, their lifetime will be halved (assuming they fail due to insulation breakdown). This sounds bad, but we have to put it in perspective - if the motors last 20 years then halving this to 10 years probably isn't a big deal.
I'd set the driver current as near as you can to the motor rating without exceeding it. You might be able to go lower, but I think it's better to ensure the machine will not stall by having a good safety margin, rather than worrying about the lifetime of the motors.
Going back to me previous point about the power supply, I just ran the simulation again but this time with both configurations. The first graph is with the windings connected in parallel on the DC side and the second graph has them connected in parallel before the rectifier:
I realise that there's not much point discussing this further, but it's interesting to note that the waveforms do look slightly better for the DC coupled version. There's still not much in it.Last edited by Jonathan; 15-08-2013 at 11:01 PM.
17-08-2013 #10
AM882's are an excellent bit of kit and really are easy to use once you get around the chinese strange way of setting up the software for programing the drives. I use them and they really do make things run very very smoothly. -Michael
Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
Denford Triac VMC year 2000 motors spec
By suesi34e in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 17-11-2013, 11:44 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM -
FOR SALE: Servo Spec gearbox's ---- Any offer considered
By Jimmybristol in forum Items For SaleReplies: 11Last Post: 30-05-2011, 11:04 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
