  1. #28
    Quote Originally Posted by Rogue View Post
    It's 625VA. It might not be very useful but it's more useful than detrimental, I suppose.
    I understood the problems with thermistors to be the time needed to cool down again if they are not taken out of the circuit - if the PSU is shut off but restarted within quite a short time, the thermistor doesn't offer enough resistance to work as an effective soft start.
    You would be fine with 625VA and no soft start circuit, so if you restart the PSU with the thermistor still hot the current is still going to be less than without anything, so either way it's not a problem.
    I'm reading everywhere that zero crossing is the worst thing with regard to inrush.
    Reference?
    if you really find a series resistor necessary, just use a resistor bypass relay powered from the DC side. By the time the DC is high enough to power the relay, any surge from bypassing the resistor should be pretty minimal.
    I used that strategy recently to charge a 0.06F capacitor bank from the mains via voltage doubler ... nice and simple. Pity what it was powering blew up.
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  1. Denford Triac VMC year 2000 motors spec
    By suesi34e in forum Milling Machines, Builds & Conversions
    Last Post: 17-11-2013, 11:44 PM
  2. Advice on spindle inverter spec
    By badgerman in forum Spindles & Drive Motors
    Last Post: 15-09-2013, 09:26 PM
  3. Hiwin linear blocks HGW 20 CC - what preload to spec?
    By range3rrr in forum Rails, Guideways & Bearings
    Last Post: 24-08-2011, 11:44 PM
  4. FOR SALE: Servo Spec gearbox's ---- Any offer considered
    Last Post: 30-05-2011, 11:04 PM
  5. System spec and Mach3
    By gorbo in forum Computer Hardware
    Last Post: 23-01-2011, 03:25 PM
