Page 3 of 3 FirstFirst 123
  1. Quote Originally Posted by boldford View Post
    They are 1K.
    Ok, so 5mA collector current on 5v, 24mA on 24v.. so it wont fry :)
    EL817 optos are rated 35v, 50mA so should be ok.
    However, as I recall the diode has a 330R series resistor so forward current is about 10mA and those devices have a transfer ratio of about 1.1. So with 10mA in the diode the collector current is going to struggle to be more than 11-12mA which means the output volts wont drop below about 12 - 13v, so though it won't fry its not going to work. No good on 24v :(
  2. #22
    Help me out here a bit folks.
    After trawling through 300-odd pages of servo amplifier manual which seems to have every bit of information you could possibly want for the Mitsubishi drive - I can't for the life of me get the faintest idea how it could be connected to accept step & direction commands from Mach 3. What is the usual command process for controlling servos?
  3. #23
    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Not all servo drives can handle step/dir. Analogue control is far more common in industrial drives, so you need a suitable interface to take the step/dir and convert them.
    Search/ask on the Mach forum (www.machsupport.com/forum), as there are a couple people on there who know about servos.
  4. #24
    Quote Originally Posted by Peter. View Post
    Give us some model numbers etc and I'll have look for you.
  5. #25
    Thanks Jazz
    Lexium LXM05CD10M2
    and
    Mitsubishi MR-J2s-10A
    Attached Thumbnails Attached Thumbnails Lexium_05_LXM05CD10M2.pdf
  1. Build Log: Servo Drive and VFD with vector control
    By Jonathan in forum Electronic Project Building
    Last Post: 05-04-2015, 07:58 PM
  2. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  3. NEW MEMBER: I am going to build a 3 axis servo control
    By markey1979 in forum New Member Introductions
    Last Post: 16-11-2011, 12:53 AM
  4. Help with spindle control
    By wizzy in forum Spindles & Drive Motors
    Last Post: 12-02-2011, 12:51 AM
  5. Help! Stepper control board
    By Ross77 in forum General Electronics
    Last Post: 28-05-2009, 01:42 AM
