Thread: My baby 15" x 15" machine
15-10-2012 #11
nope i have all the welding gear now, but i'm still struggling getting my design down in goolge sketchup and until i do this i dont want to start, plus the money i thought we were getting got swallowed up by other things :/ life sucks atm
15-10-2012 #12
cheer up cock. I agree with you wanting to get the design right before you start or buy things im in the same boat. Ive been desgining mine for months now, Ive just decided that i cant keep drawing ive just got to get on and try a bit lol. Im %90 there on design, the rest i can make up as i go along sucessfully im sure. Have you any sketches, plans etc to show, perhaps we could give you some input or a lift?
26-10-2012 #13
finally getting somewhere with sketchup, i wanna run this past you lot before i progress this further
the 2 small piece of box section are 25 x 50mm steel box and i'm hoping to mount the router straight to them with a bracket i will design later down the line..
what i want to check is that the rails are not too far away from the router.. the box section the rails are mounted on is 50 x 50mm steel so that puts the base of the rails 75mm away from the base of the router support
and also the piece that the ball screw is mounted to is 10mm. firstly can i easily cut through 10mm steel with a holesaw? as thats the only way i'm going to be able to cut it? if not is 10mm thick ally enough considering how close the box section will be either side to support it?
27-10-2012 #14
Wilfy
Swap your rails and bearing blocks round, put your blocks where your rails are now and have the rails move up and down with your Z axis.
Andy
27-10-2012 #15
27-10-2012 #16
Sorry thought the rails was on the front of the axis didn't realise is was the rear view.
Put the blocks as low as possible and space them as wide in both ways as you can.
27-10-2012 #17
guys whats the difference between using BK or FK blocks for the ballscrew supports?
27-10-2012 #18
IIRC BK blocks allow you two mount them in two planes, perpendicular AND paralell to the screw. FK only allow mounting in 1 plane, paralell to the screw.
Hobgoblin.
27-10-2012 #19
hmm i only acctually want to mount parallel with the screw, i've seen some bk blocks though with no holes to mount parallel
27-10-2012 #20
You've seen something like this:
https://encrypted-tbn1.gstatic.com/i...zASIlIFuCNK-Xw
But I mean this type:
https://encrypted-tbn3.gstatic.com/i...Z8-RTUSbeJz49zHobgoblin.
Help on a couple of "niggles" with my machine.
By Washout in forum Machine DiscussionReplies: 4Last Post: 24-04-2014, 12:30 AM -
Now that's what ya call a "BIG" CNC machine.!!
By JAZZCNC in forum General DiscussionReplies: 7Last Post: 08-04-2014, 11:25 PM -
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
Calibrating my new machine - "never the same twice" woes
By HankMcSpank in forum General DiscussionReplies: 4Last Post: 23-11-2011, 05:54 PM
