Thread: New machine Ideas
18-09-2012 #1
Hey all, I may be selling my machine and building a bigger and better one,
one thought though, after using the chinese BK / BF blocks is that they're crap and the mounting holes are worse.
what does a BK block comprise of?
is it just and alu block, with a bearing pressed in and then a four screw cover to clamp it down?
has anyone made one before? if so was it difficult? As I can chuck it on my current CNC and make some parts for it :)
also, do I want an angular contact bearing or a double row bearing?
Thanks!
19-09-2012 #2
I will never use BK/BF blocks on my machine - yes they can work but they need a varying amount of TLC so I prefer to just make my own as then I know it will be accurate and can make it a better shape to fit the available space.
The BK blocks are just mild steel, but it's easier to machine aluminium so I use that. You need to bore the block to the width of two angular contact bearings, put a cover on the front to press on the outer ring of the bearings to retain them and if they're single row cheap bearings you'll need a shim between them. There are plenty of examples of bearing arrangements elsewhere on this forum / CNCzone.
New Gantry Ideas
By Tomnewry in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 05-02-2014, 10:00 PM -
BUILD LOG: 5'x3' Ideas and build.
By Wal in forum DIY Router Build LogsReplies: 17Last Post: 29-12-2012, 02:03 AM -
Need some ideas
By jpcnc in forum Machine DiscussionReplies: 20Last Post: 29-01-2011, 07:56 PM -
your ideas on a pipe profiling machine
By D-man in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 03-11-2010, 05:09 PM -
Any ideas on the best use of this????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 01-08-2010, 11:41 AM
