Thread: where to start
The 6560`s can be a bit fragile, as I`ve learned, but easy to change out, once you`ve done it once....
More limiting , as Jazz continually points out ;-), is the maximum voltage is lower than any other drive, so changing motors will only happen with the drives as well.
542 drives can stay around with bigger motors and are less fragile to start with, in this case cheaper.
MDF frame gets you a working test bed to learn a bit about software and probably get the cash back in for MKII ;-)
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start?
By trounce in forum Gantry/Router Machines & BuildingReplies: 44Last Post: 03-10-2011, 02:03 PM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM -
NEW MEMBER: Were do I start?!
By tonygagey in forum New Member IntroductionsReplies: 4Last Post: 07-08-2010, 07:55 PM -
Where to start?
By ricey3 in forum Computer SoftwareReplies: 10Last Post: 25-10-2009, 08:01 PM
