Thread: Adjusting speed with vfd
Oh dear. I do not know how to adjust the speed on my vfd invertor. Some clues please.
Also I have noticed that one of the membrane switches on the control unit, the set button, no longer clicks. Not sure if its working or not. Anyone blown up an invertor and could supply me with the small unit I would be grateful.
I have done a small test cut but only have a spindle speed of 7200 rpm. As soon as I do a 'proper' cut you lucky people will be treated to a video. I know, you can't wait.
Bruce
this maybe is not clear. I have tried the up and down arrow keys when it is on freq or rpm and that does not change it. I presume that here is a setting \i need to alter. What really gauls me is when I gor this and tested it months ago Jonathan explained this to me. Old age is my best excuse.Last edited by motoxy; 18-09-2012 at 10:06 PM. Reason: bit more info
The more I know, I know, I know the less. (John Owen)
19-09-2012 #2
Amazing. 41 people have looked at this post and none of them seems to have known how to adjust the speed of a spindle using a vfd. I realise probably the up and down arrows are the answer and my problem is that I have a faulty control pad. I was just wondering if I was missing anything obvious.
BruceThe more I know, I know, I know the less. (John Owen)
19-09-2012 #3
It depends on the VFD.. with one of mine I have to press RUN, then select the 'Hertz' display mode, then the up and down arrows control the speed; with the other I have to select SET 01, up/down, Enter...
If you said what VFD it was make/model you could get a better answer... :)
The Following User Says Thank You to irving2008 For This Useful Post:
19-09-2012 #4
23-09-2012 #5
Is this the one? https://docs.google.com/viewer?a=v&q...1W_iXayyq0EA-A
24-09-2012 #6
That is the one. I had the manual but just could not remember how to adjust the speed. Its not clear in the manual and I had forgotten that its the frequency you adjust and then monitor the rpm. Thanks for your effort Adie
19-09-2012 #7
Dont use the keypad. Fitted a pot and use that instead.
19-09-2012 #8
19-09-2012 #9
OOps
INPUT:3PH380V50Hz
OUTPUT:3PH380V17.5A7.5KW
Freq-Range: 0.1~400Hz
HUANYANG ELECTRONICS CO., LTD.
Safe Z Speed
By dudz in forum Artsoft Mach (3 & 4)Replies: 23Last Post: 24-05-2014, 04:08 PM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
Top speed failing after a bit
By Robin Hewitt in forum Machine DiscussionReplies: 6Last Post: 12-11-2011, 12:46 PM -
speed controler
By Scott in forum Machine DiscussionReplies: 13Last Post: 04-11-2010, 10:02 PM
