  1. It depends on the VFD.. with one of mine I have to press RUN, then select the 'Hertz' display mode, then the up and down arrows control the speed; with the other I have to select SET 01, up/down, Enter...
    If you said what VFD it was make/model you could get a better answer... :)
  2. The Following User Says Thank You to irving2008 For This Useful Post:
  1. Safe Z Speed
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 24-05-2014, 04:08 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  4. Top speed failing after a bit
    By Robin Hewitt in forum Machine Discussion
    Last Post: 12-11-2011, 12:46 PM
  5. speed controler
    By Scott in forum Machine Discussion
    Last Post: 04-11-2010, 10:02 PM
