Thread: Terminal blocks
    Well, I know what I mean but I suspect that the term I've always used for them might be wrong...
    I'm looking for a neat way of combining/splitting (depending on your perspective) wires. In the past I've used what I thought were "terminal blocks" that had a number of terminals connected together physically and electrically. I preferred them to just twisiting lots of wires together and slapping a ton of solder and some electrical tape on the resulting mess
    However... when I search for that term I'm only finding the blocks with multiple isolated single poles.
    I know what I want and I've used them before but I'm blowed if I know what search term I need for them. Can anyone give me a pointer?
  2. The Following User Says Thank You to Rogue For This Useful Post:
  3. #2
  4. The Following User Says Thank You to Web Goblin For This Useful Post:
  5. #3
    If I am thinking of the same thing we use to call it chocolate block in the Navy, if you go a google search for chocolate block connectors you will get loads of links. Can't help with best place to buy but any electrical factors should be able to help.
  6. #4
    The ones I was thinking of looked very much like the "other" terminal blocks/strips that you often see in household wiring.
    Not that I need that exact kind, but they were cheap and neat. The ones you've linked look like they're tophat DINs and need wiring up to link together.
    In theory I could get the single-pole blocks and daisychain them together to make what I want, but I'd prefer something made for the job as it were, especially if I'm using mains. This is to split one 240VAC input out to 3 or 4 bits of kit (ie transformers 'n' stuff)
  7. #5
    Mains voltage is not a problem. Further down the page on the right hand side you will find a link to jumper kits for these connectors which are used to correctly link them together. These are standard kit in industrial stuff and make for a really good job. You can also get fused terminals as well if you want individual protection for each circuit.
  8. #6
    Quote Originally Posted by martin54 View Post
    Aha! Chocolate block sounds familiar.
    "Multiple screw terminals can be arranged as a barrier strip, with each short metal strip having a pair of screws. This is used for connecting two different components, one on each side of the pairs. This arrangement is common in luster terminals, as pictured at left. These are known as connector strips or chocolate blocks in the UK. Conversely, terminals can also be arranged as a terminal strip or terminal block, with several screws along (typically) two long strips. This creates a bus bar for power distribution, and so may also include a master input connector, usually binding posts or banana connectors."
    That's what I'm after, but most of the stuff I see actually seems to be a "connector" strip.
  9. #7
    Aha, then we're onto something!
    edit: On reflection, while I like the idea the sheer size of them is out of proportion for the project.
  10. #8
    How many mains cables do you want to join? Another option would be a 2 or 3 way mains junction box like these
    30A 3 WAY WHITE JUNCTION BOX - MAINS POWER CABLE JOINER TERMINAL on eBay!
  11. #9
    I'll slip in a link to one of Irving2008's posts to save me having to describe or draw too much >check image in this post< note the mains here splits to three outputs. This was the image that triggered the search though I want the stuff for a few other projects as well, where 5-8 connections would be useful. Something which works without taking up a lot of space would be nice as well.
    My usual approach would be lots of twisting, a bit of solder and some 'leccy tape. This time I want to make it look neat, tidy and semi-amateur (as I doubt I'll ever achieve full amateur status).
    I guess something like this would work, but the blocks I was thinking of would be simple to fix in place and make it easy to add/remove/change wires if needed.
    Mostly I'm annoyed because I know what I want, it seems simple enough but I can't find it and I'm too stubborn to move on
  12. #10
    I bought some of these lever connection blocks. They can handle wire upto 4mm2 stranded wire or 2.5mm2 solid wire and rated at 400v 32A. Click image for larger version.
Name:	lever connector.jpg
    or something like this for 8 wires they are push to lock and twist to release.
    I went ahead and bought a mixed 100 piece bulk pack of 2-8 input connectors. They always come in handy.
  1. What is the best way to mark out for bearing blocks and linear rails?
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 18-05-2014, 02:08 PM
  2. Needing advice on linear rail blocks
    By oldmam4m80s in forum Rails, Guideways & Bearings
    Last Post: 27-10-2013, 07:57 AM
  3. Clamping sets / Step blocks and clamps
    Last Post: 10-06-2013, 06:03 AM
  4. FOR SALE: HIWIN & THK guide blocks and rails
    By vigen20 in forum Items For Sale
    Last Post: 27-02-2013, 10:37 AM
  5. Bearing Blocks
    By GTJim in forum Rails, Guideways & Bearings
    Last Post: 15-01-2013, 07:18 PM
