Thread: Terminal blocks
19-09-2012 #4
Aha! Chocolate block sounds familiar.
"Multiple screw terminals can be arranged as a barrier strip, with each short metal strip having a pair of screws. This is used for connecting two different components, one on each side of the pairs. This arrangement is common in luster terminals, as pictured at left. These are known as connector strips or chocolate blocks in the UK. Conversely, terminals can also be arranged as a terminal strip or terminal block, with several screws along (typically) two long strips. This creates a bus bar for power distribution, and so may also include a master input connector, usually binding posts or banana connectors."
That's what I'm after, but most of the stuff I see actually seems to be a "connector" strip.
What is the best way to mark out for bearing blocks and linear rails?
By gavztheouch in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 18-05-2014, 02:08 PM -
Needing advice on linear rail blocks
By oldmam4m80s in forum Rails, Guideways & BearingsReplies: 0Last Post: 27-10-2013, 07:57 AM -
Clamping sets / Step blocks and clamps
By dudz in forum Marketplace DiscussionReplies: 3Last Post: 10-06-2013, 06:03 AM -
FOR SALE: HIWIN & THK guide blocks and rails
By vigen20 in forum Items For SaleReplies: 8Last Post: 27-02-2013, 10:37 AM -
Bearing Blocks
By GTJim in forum Rails, Guideways & BearingsReplies: 1Last Post: 15-01-2013, 07:18 PM
