20-09-2012 #1
I'm running (or going to run) 2 motors on my longest axis. I also have 2 drivers. How should I connect the two drivers to the breakout board?
Should I run each driver as a completely separate axis, or should I run each driver from the same axis on the breakout board. I believe each driver has some series resistance at the input so it should be okay to parallel them I guess on the same breakout board axis.
Thanks!
20-09-2012 #2
You can do it either way... Mach3 can slave two axis together, or drive both drivers from one BOB output. If you do the latter and the drivers have opto-isolated inputs you need to be sure the BOB can drive two inputs. Its unlikely it can't. What BOB & drivers are they and I'll check it.
20-09-2012 #3
Hi Irving, I've got a HG07 BOB from CNC 4 U and the parallel drivers are CW8060. I'll just slave the axis in Mach3 to be certain it doesn't upset the hardware, I have enough outputs from the BOB.
Stepping Motors & Drivers
By irving2008 in forum Stepper & Servo MotorsReplies: 3Last Post: 28-04-2015, 09:37 PM -
matching drivers to existing motors
By 2006Nobull in forum Motor Drivers & ControllersReplies: 3Last Post: 17-07-2012, 08:27 PM -
CNC rebuild ,matching drivers to motors
By 2006Nobull in forum Electronic Project BuildingReplies: 1Last Post: 17-07-2012, 04:09 PM -
Two ball screws for my x axis and two motors, do i need two drivers?
By luke11cnc in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 12-08-2011, 12:55 AM -
Motion Control drivers and motors
By bruce_miranda in forum Motor Drivers & ControllersReplies: 71Last Post: 27-08-2009, 09:40 AM
