Tonnage is the force applied to clamp the mold together. The bigger the mold the more tonnage you need to hold the mold together and prevent the plastic from running out of the shut lines ( flash). This machine is too small to make a standard builders buckets, a limiting factor for the part size is the distance between the tie bars. If the bars are too close together you can't get the mold into position. The machine would need to open up wide enough to eject the bucket.
Injection pressure is another factor, bigger machines can squirt more plastic before the liquid plastic begins to solidify. If you have thin walled parts this is even more important as the thin areas will cool faster and block any more plastic getting in to fill the mold.CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
17-03-2014 #2
It's also a 5yr old thread and probably in a scrap yard now. .
17-03-2014 #3
You don't have an injection speed control? How passé
Hi Progomez
You want to make sure you get a copy of the manual with your moulder, without that you are totally screwed.
Depending on the diameter of the plasticizer screw fitted the manual will give you the shot volume. I have an 18mm screw which gives me usable shot volume of 19cc's.
good luck
Robin
25-10-2014 #4
Do you still have this machine Robin, did you ever make a mold for it?
ADD ME ON FACEBOOKS
25-10-2014 #5
I still have it, I vastly underestimated mould making but I have not given up yet
26-10-2014 #6
How much stuff do you have stored on top of it?
- Nick
26-10-2014 #7
Plastic injection mold making forum?
By gavztheouch in forum Moulding MachinesReplies: 26Last Post: 13-10-2022, 11:31 AM -
RFQ: Any Injection Moulders on here, before I buy Chinese ?
By Bazzer in forum Projects, Jobs & RequestsReplies: 11Last Post: 18-05-2013, 11:25 AM -
FOR SALE: spindle moulder / morticer
By uppy121 in forum Items For SaleReplies: 0Last Post: 05-04-2013, 02:26 PM -
DIY Injection moulding by JR Hartley.
By HankMcSpank in forum Moulding MachinesReplies: 26Last Post: 04-01-2013, 12:41 AM -
Proxxon MF70 for making injection molds
By forrest in forum Moulding MachinesReplies: 8Last Post: 11-04-2012, 11:30 PM
