I'm looking at the pdf's but cant seem to discover the spacing for the holes bolting through from the top. I can see the pitch is 46mm in one axis, but in the other i cant cleary work out what the sizes are, pitch, from which edge etc.
Thanks for any help offered.
21-09-2012 #2
If you have a look here : http://www.zappautomation.co.uk/pdf/...tor-mounts.pdf you can scroll through the info pdf and find the dimensions for the BK12
21-09-2012 #3
perfect, thanks webgoblin. The pdf i had wasnt as clear as this.
WANTED: BK12 Bearing Block Wanted - 1 off
By EddyCurrent in forum Items WantedReplies: 7Last Post: 11-03-2017, 08:52 PM -
BK12 end float?
By birchy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 20-07-2013, 02:28 AM -
Bearing Spacing on Y-Gantry-Carriage
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 29-10-2012, 01:16 AM -
Dimensions and Weight of Denford Starmill PC Please
By cristec in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-08-2012, 07:02 AM -
BK12 & BF12 bearings
By mlmSolutions in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 04-01-2011, 11:16 AM
